SoftMaker.com
English-Language Support
It is currently Thu Sep 02, 2010 10:38 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: PlanMaker on OpenBSD 4.1
PostPosted: Thu May 17, 2007 7:07 pm
Offline
Hi Tobias:
PlanMaker 2006 for Linux is working really well on OpenBSD 4.0 and 4.1.
For OpenBSD:
Install the RedHat or Fedora Core packages from ports (or the ftp site). PlanMaker and TextMaker seem to run better with the more recent Fedora Core *.rpms.
Copy the PlanMaker */tar.gz to /emul/linux/usr/bin/ and untar it.
Enable Linux emulation by changing the following in /etc/sysctl.conf, from
#kern.emul.linux=1
so that it reads
kern.emul.linux=1 # enable running Linux binaries
Finally, do (as root)
# sysctl -w kern.emul.linux=1
to get PlanMaker to run for the first time. On subsequent boots, the
the Linux emulation will be started by /etc/sysctl.conf
To use PlanMaker or TextMaker you have to specify the absolute path like so:
/emul/linux/usr/bin/office/textmaker
___________________________________________________
Also to enable printing in OpenBSD I am including the following:
These examples are based on OpenBSD 4.1 on i386. They should also work for OpenBSD 40. and 3.8. They are for an HP 6940 Deskjet. substitute the appropriate HP model number for your printer.
IMPORTANT: You can only use HP printers with the hpijs printer. It won't
work with Epson, Lexmark or other printers.
1) Go to http://www.openprinting.org and look for the Deskjet 6940 *.ppd (or whatever your *.ppd should be). Download the *.ppd.
2) Install a2ps from packages.
pkg_add ftp://ftp.openbsd.org/pub/OpenBSD/4.0/packages/i386/a2ps*.tgz
(where the * denotes the appropriate version.
3) pkg_add ftp://ftp.openbsd.org/pub/OpenBSD/4.0/packages/i386/hpijs*.tgz
to install the HP print driver
4) Copy HP-DeskJet_6940-hpijs.ppd to /usr/local/sbin/
5) Modify your /etc/printcap so that it looks like this:
lp|HP6940:\
:lp=/dev/ulpt0:\
:af=/usr/local/sbin/HP-DeskJet_6940-hpijs.ppd:\
:if=/usr/local/bin/foomatic-rip:\
:sd=/var/spool/output/lp:\
:lf=/var/spool/output/lp/log:\
:mx#0:\
:sh:
This assumes that you are using a USB printer.
6) Go to /var/spool/output
# cd /var/spool/output
do: #mkdir lp
then do: #chown daemon:daemon lp/
as root.
7) As root do: # touch /var/spool/output/lp/log
8) edit /etc/rc.conf by changing the variable lpd_flags=NO to lpd_flags=""
9) Add your hostname to /etc/hosts.lpd.
10) Reboot the computer and printing should be working.
11) You may need to change the defaults in /etc/a2ps-site.cfg.
See
http://www.infres.enst.fr/~demaille/a2p ... s_toc.html
for details on configuring the a2ps-site.cfg
Also, change the /etc/a2ps.cfg line:
# 3) Default settings #
# Two virtual pages per sheet
Options: -2
To:
# Options: -2
# One virtual page per sheet
Options: -1
Note that the Options -2 has been commented out.
Top
 Profile
 Post subject:
PostPosted: Mon May 21, 2007 8:37 am
Offline
Thanks for this great HowTo to run our software on OpenBSD.
_________________
Tobias Leißner
Top
 Profile
Who is online
Users browsing this forum: No registered users and 0 guests
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
