SoftMaker.com
English-Language Support
It is currently Wed Jun 19, 2013 7:24 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
PostPosted: Fri Oct 09, 2009 6:31 pm
Offline
When copying a range of rows with intervening hidden rows (such as a filtered range), Microsoft Excel copies just the visible rows (providing one drag-selects rather than doing a shift-select to get the whole range). Planmaker, on the other hand, only copies rows up to the first hidden row. Is there any way to change this behavior?
Top
 Profile
PostPosted: Sat Oct 10, 2009 5:17 pm
Offline
When you do the copy, are you selecting using the row numbers? Or are you selecting the actual cells? I just tried this and if I select the numbers, I only get the first row as you point out, but if I use a click-shift,click to select a block of rows, I get everything including the hidden rows.
_________________
Cheers
Jim
Top
 Profile
Who is online
Search for:
Jump to:
