SoftMaker.com
English-Language Support
It is currently Tue May 21, 2013 10:17 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Sun Aug 16, 2009 7:56 am
Offline
Is this not possible or am I missing something? I am used to being able to select Search, then click either something like This Worksheet Only or Entire Workbook and have it automagically search all tabs in the entire workbook.
Being a CPA (Certified Pain in the Ars), I have workbooks that go back 10+ years with a tab for each month. When I need to search, I need to search each and every tab, not just the one I am on.
Dobermann
Top
 Profile
PostPosted: Sun Aug 16, 2009 10:48 am
Offline
This feature will be included in the next Version of PlanMaker
Top
 Profile
PostPosted: Mon Aug 17, 2009 12:34 am
Offline
Okay, thanks for the update. I will look forward to it.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
cron
