SoftMaker.com
English-Language Support
It is currently Sun May 19, 2013 7:33 pm
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Mon Aug 03, 2009 5:56 am
Offline
Standard, Status, Format & Edit toolbars each have vacant space to the side of them. Each of them take up precious vertical real estate. With other programs, I was able to place one next to the other, thereby reducing the vertical space used by toolbars.
Is this another feature that PM does not have or am I again missing something? I was thinking about modifying one of the toolbars to add the icons from another, but before I go through that, is there another way? Also, if I do that, what is the name of the file that saves these custom settings?
Thanks,
Dobermann
Top
 Profile
PostPosted: Mon Aug 03, 2009 10:56 am
Offline
Hello,
there is no way to drag a toolbar into another one but you can edit the toolbars and add/delete icons from them via Tools=>Customise=>Toolbars.
Your settings are saved in My Documents\SoftMaker\Settings\pmwconfig.ini
_________________
Top
 Profile
PostPosted: Tue Aug 04, 2009 1:32 am
Offline
Again Sven, thanks for the quick & complete answers!
Super Service!!
Dobermann
Top
 Profile
Who is online
Search for:
Jump to:
