SoftMaker.com
English-Language Support
It is currently Thu May 23, 2013 5:33 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Subdividing a Page
PostPosted: Fri Feb 05, 2010 8:59 pm
Offline
Is it possible to subdivide a page in TextMaker? I am migrating to this superb software from WordPerfect and use that feature quite a bit. I worked around it for a landscape mode page by making two colums, but when a page is in portrait mode and I want to make two rows, or divide the paper top and bottom with margins, I cannot find where to do that.
Thanks for any help!
Harald
Top
 Profile
 Post subject: Re: Subdividing a Page
PostPosted: Fri Feb 05, 2010 9:58 pm
Offline
Hi Harald, I'm not sure if I quite understand your problem. There are lots of ways to subdivide a page in TextMaker, so could you please describe more in detail what exactly you want to accomplish?
Cheers
Top
 Profile
PostPosted: Fri Feb 05, 2010 10:49 pm
Offline
Thanks so much for the quick response Jossi. I want to take a page, in portrait mode and divide it top to bottom in half, so that I have half inch margins all around both halves of the subdivided page. Essentially instead of having two vertical columns, I want to have two horizontal rows, each of them half of the page.
Harald
Top
 Profile
PostPosted: Sat Feb 06, 2010 12:03 pm
Offline
I think you are thinking in a too complicated way... :wink:
Simply go to object mode, insert two text frames and position them accordingly. If text should flow from one frame to the other, link them.
_________________
Top
 Profile
PostPosted: Sun Feb 07, 2010 11:16 pm
Offline
Thanks so much Martin. I am obviously not used to using text boxes in that way. I am used to being able to do that simply in the document setup page with check boxes to divide my paper into however many sections I want.
Will do you suggestion!
Harald
Top
 Profile
PostPosted: Wed Feb 10, 2010 12:01 am
Offline
Thanks for the help. Making text boxes certainly works, but is much more complex than what I was accustomed to in WP. I will just create several templates of the way I usually use this feature and then be ready to go when I need them. :)
Harald
Top
 Profile
Who is online
Search for:
Jump to:
