SoftMaker.com
English-Language Support
It is currently Fri Sep 10, 2010 6:49 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: SMASH.exe
PostPosted: Fri Aug 07, 2009 10:39 am
Offline
SMASH.EXE - what is it? What does it do? Can it safely be removed or deactivated (I have an NC10 withj 1Gb of RAM and I want to keep it as clean as possible)
Top
 Profile
 Post subject: Re: SMASH.exe
PostPosted: Fri Aug 07, 2009 12:52 pm
Offline
Hello,
SMASH = SoftMaker Application SHell, which means it's a quick starter for our application. It gets placed into the system tray. When double clicking at a program icon there, the corresponding program gets loaded.
You can disable smash by invoking Start=>Run, type: msconfig.exe and press Enter, change to "Startup" and remove the tick left from "Smash".
_________________
Top
 Profile
PostPosted: Fri Aug 07, 2009 2:37 pm
Offline
That's very useful to know! I have found a way to remove it from the icon tray but now I want it back again (for both TextMaker 2006 and for PlanMaker 2006). Have you any advice (short of reinstalling) how I can reinstate SMASH icons for TM and PM to the status bar?
Top
 Profile
PostPosted: Fri Aug 07, 2009 2:55 pm
Offline
You can stat it every time manually:
Start=>Programs=>SoftMaker Office=>Utilities=>Smash
_________________
Top
 Profile
Who is online
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
