SoftMaker.com
English-Language Support
It is currently Fri May 24, 2013 9:57 pm
Post new topic Reply to topic  [ 10 posts ]
Author Message
PostPosted: Fri May 04, 2012 5:23 pm
Offline
I'm experiencing some character encoding issues when using copy/pase from OpenOffice/Libre Office Calc to PlanMaker 2012.
Special Polish characters are not preserved:
Copy/paste for Writer to TextMaker or even from web browser to PlanMaker works OK.
Top
 Profile
PostPosted: Mon May 07, 2012 3:40 pm
Offline
Could you please attach a sample file or send it to forum(at)softmaker.de? Thank you!
_________________
Top
 Profile
PostPosted: Mon May 07, 2012 5:19 pm
Offline
Attached a sample file.
I think this happens because when I copy from Calc to PlanMaker default paste format is set to 'Sylk' (Paste Special -> Formatted text (RTF) or Paste Special -> Unformatted text both work without problems)
Aslo copying form PlanMaker to Calc works. This only happens when copying from Calc to PlanMaker.
copy test.ods [9.43 KiB]
Downloaded 71 times
Top
 Profile
PostPosted: Tue May 08, 2012 11:00 am
Offline
You attached an .ods file. PlanMaker does not yet support .ods files (neither read nor write). This is on the wish list for future versions.
_________________
Top
 Profile
PostPosted: Tue May 08, 2012 11:12 am
Offline
sven-l wrote:
You attached an .ods file. PlanMaker does not yet support .dos files (neither read, nor write). this is on the wish list for future versions.
Yes, I know.
+1 for ods support btw.
I made this file in OpenOffice. To test the bug you'll have to open it in OpenOffice Calc and copy/paste to PlanMaker.
Top
 Profile
PostPosted: Tue May 08, 2012 12:00 pm
Offline
Yes, you are right. :oops:
I can now reproduce the problem here and informed the developers. Thank you!
_________________
Top
 Profile
PostPosted: Tue May 08, 2012 1:30 pm
Offline
It seems that this is not a bug. It is the same when pasting from Open Office to Excel.
Reason: The text is copied in various formats into the clipboard: Sylk, RTF and Unicode text. Sylk is an explicit spreadsheet format, so it's preferred, but as it's very old it can't transport unicode characters.
Workaround: Paste/Special, select Unformatted text. This works.
_________________
Top
 Profile
PostPosted: Tue May 08, 2012 2:03 pm
Offline
Actually the reason why I posted this issue here is that I don't have any problems when copying from Calc to Excel (we have MS Office 2010 at work). Using 'paste special...' can be really annoying if I have to do a lot of copy/paste tasks.
I would prefer RTF format for copy/paste operations (I think it's default for OpenOffice or Excel). Wouldn't it be better to make it default format instead of 'old' Sylk?
Top
 Profile
PostPosted: Tue May 08, 2012 2:35 pm
Offline
I will refer this as a suggestion for future versions to the developers.
_________________
Top
 Profile
PostPosted: Wed May 09, 2012 11:25 am
Offline
Thank you :)
Top
 Profile
Who is online
Search for:
Jump to:
cron
