SoftMaker.com
English-Language Support
It is currently Wed May 22, 2013 12:33 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Mon Feb 20, 2012 7:52 am
Offline
What support does TextMaker 2012 have for working with multiple documents? ... say 3 open at the same time ... and dragging blocks of text from one to another?
Can three copies of TextMaker be open simultaneously (with individual documents)?
Or is there a tabbed type interface ... with a drag and drop feature of some sort?
Working with two or three open documents is very common in my work environment. I'm anxious to hear what good solutions you might have.
Thanks.
Top
 Profile
PostPosted: Mon Feb 20, 2012 12:08 pm
Offline
Only one instance of TextMaker can be open at a given time, but inside the application you can open as many documents as you like. There are document tabs and functions for arranging document windows conveniently. Drag & Drop between document windows doesn't work, but you can exchange text between documents by Ctrl+C/Ctrl+X and Ctrl+V.
Top
 Profile
PostPosted: Mon Feb 20, 2012 4:54 pm
Offline
Jossi wrote:
... There are document tabs and functions for arranging document windows conveniently. Drag & Drop between document windows doesn't work ...
That's a little confusing. So I can be viewing two documents side by side? ... Yes? (i.e., with both documents in TextMaker)
But I can't drag a paragraph from one to the other? How about dragging to/from another word processor? Will that work?
In a few days, I'll download the trial copy and see what you mean.
Top
 Profile
PostPosted: Mon Feb 20, 2012 7:26 pm
Offline
Yes, you can! ;-) Two, three, four, or as many as your screen real estate will yield.
No, this isn't possible.
The result will be an OLE-object (if the other word processor is OLE-enabled, e.g. Word). So, for simply copying text, you're back at copy & paste.
Top
 Profile
Who is online
Search for:
Jump to:
