SoftMaker.com
English-Language Support
It is currently Tue May 21, 2013 4:04 am
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Unicode support
PostPosted: Thu Jan 12, 2012 10:26 am
Offline
I'm trying to create a Textmaker version of a stylesheet I've used in a number of other applications, and I want to specify Unicode 2756 (dingbats ❖ 2756 BLACK DIAMOND MINUS WHITE X) as a bullet using Arial. The character is available to other applications, both on Windows and on Ubuntu – but it doesn't show up in the Character dialog and I can't directly select it using its Unicode value.
Is there a workaround? Thanks in advance.
_________________
Niels Grundtvig Nielsen
You know what you're talking about ‒ I can help you say it
http://www.kbss27.be
Top
 Profile
 Post subject: Re: Unicode support
PostPosted: Thu Jan 12, 2012 12:33 pm
Offline
The answer is here:
http://www.softmaker.com/forum/viewtopic.php?f=139&t=9878&p=37021#p37021
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
cron
