SoftMaker.com
English-Language Support
It is currently Wed Jun 19, 2013 9:11 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Tue Jul 17, 2012 12:36 pm
Offline
Dear Softmaker,
I use standard Debian 6 and I just bought SMO2010 for Linux after few days of tests. I didn't expect that such problem can exist today ;-)
Whole Debian can handle Czech with accent chars with no problem. In gedit I can write accented n (ň) and is displayed correctly, same with ť.
These 2 chars are specific as they are not available on keyboard and to get these, shift & '+' and then 'n' or 't' must be pressed.
Is there any fix for this ?
despite ň is not very often, is required
thanx
Adam Sida
Top
 Profile
PostPosted: Wed Jul 18, 2012 8:58 am
Offline
I referred that problem to the developers and will inform you here as soon as I have more information.
Workaround: You can define hotkeys for every character via Insert=>Symbol.
_________________
Top
 Profile
PostPosted: Wed Jul 18, 2012 10:56 am
Offline
Could you please tell us your revision number in Help=>About in TextMaker? It should be rev 600.
_________________
Top
 Profile
PostPosted: Mon Dec 03, 2012 2:58 pm
Offline
This problem has been fixed and should work with the current version if the UTF-8 locale is installed.
_________________
Top
 Profile
Who is online
Search for:
Jump to:
