SoftMaker.com
English-Language Support
It is currently Tue May 21, 2013 9:24 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
PostPosted: Mon Aug 29, 2011 9:04 pm
Offline
why is it set to start with widows?
I've been trying to find info about it with google to no avail,
Thank you
Top
 Profile
PostPosted: Tue Aug 30, 2011 6:08 am
Offline
Greetings.
SMASH is an acronym for “SoftMaker Application SHell”. It is described (see below) as being used to display icons for the various members of SoftMaker office. A right click on it will cause a list of sortcuts for (quasi) common actions to appear.
While I certainly appreciate SoftMaker's obsequious attention to the (possible) needs of its customers, I'm not sure that my life would be measurably diminished without SMASH. On the chance that you are not as tough as I am <g>, I've attached a few SMASH screen shots for your review.
As far as SMASH starting with Windows, surely you can ask it not to? The “Preferences” menu (screen shot also attached) gives one the choice of having or not having SMASH start automatically; doesn't this work for you? Or haven't you tried it?
Cordially,
Richard Kanarek
SoftMaker Customer
Here is the introduction to SMASH from its help file:
[quote]
Welcome to SMASH, the “SoftMaker Application Shell”.
SMASH is a little utility that displays icons for your SoftMaker Office applications in the system tray (at the bottom right corner of your screen). Clicking on these icons provides a very fast and easy access to your SoftMaker Office applications and documents.
Starting SMASH
Unless you have unchecked it during the installation procedure, SMASH will be installed in a way that it is launched automatically every time you start Windows.
Alternatively, you can start SMASH manually using Windows’ Start menu. To do so, click on Start > Programs > SoftMaker Office > Auxiliary Programs > Smash.
[/quote]
Top
 Profile
Who is online
Search for:
Jump to:
