SoftMaker.com
English-Language Support
It is currently Sun May 26, 2013 10:20 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Fri Aug 06, 2010 8:13 pm
Offline
In PlanMaker 2010 for Windows (rev 584), under Windows XP, using "Classic" keyboard mappings, Ctrl+H doesn't work for me for "Back" (backspace), even though Ctrl+H IS shown as the "Current shortcut key" for that function in Edit Keyboard mappings. I've made no modifications to the keyboard mappings. Is there a way to enable Ctrl+H as backspace?
I bought SoftMaker Office specifically because of its WordStar-compatible keyboard interface, and Ctrl+H DOES work properly in TextMaker 2010. Help, please! :)
ROBERT J. SAWYER, Science Fiction Writer
Author FLASHFORWARD, basis for the TV series
http://sfwriter.com * sawyer@sfwriter.com
Top
 Profile
PostPosted: Tue Aug 10, 2010 7:39 am
Offline
Dear Robert,
thank you for the bug report. It seems that there is a problem in TextMaker with the hotkey CTRL+H working as backspace. Our developers are working on a bugfix. I will inform you as soon as we have a solution.
_________________
Top
 Profile
PostPosted: Tue Aug 10, 2010 12:00 pm
Offline
The problem has been solved now and won't occur any longer with the next service pack.
_________________
Top
 Profile
Who is online
Search for:
Jump to:
cron
