SoftMaker.com
English-Language Support
It is currently Sat May 25, 2013 4:05 am
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Why just 256 columns?
PostPosted: Sat Dec 19, 2009 11:42 am
Offline
I use Excel to study data I'm outputting to a CSV file. My data files are typically several hundred rows by several hundred columns (200x1000, 500x500, ...). Excel supports 16384 columns, so this works fine, but PlanMaker won't work for this, since it's limited to 256 columns. It'd be nice if it supported more.
Top
 Profile
PostPosted: Mon Dec 21, 2009 9:54 am
Offline
Hello,
that's because the XLS format (the dominant exchange format for PlanMaker users) supports only 256 columns. When our XLSX export filter is done, we can raise the limit.
_________________
Top
 Profile
Who is online
Search for:
Jump to:
cron
