Hello,
I recently upgraded to Softmaker Office 2010 and for the most part really like the software. There is at least one compatibility issue in Planmaker that is a show stopper for me. I exchange Excel 2003 files with many users and within our organization we use a date standard of MM/DD/YYYY and have since the year 2000 "incident". So any Excel file will have this date format.
When opening one of them in Planmaker 2010 Rev 569, Planmaker changes the date format to DD/MM/YYYY and also inserts a 0 (zero) in the leading month first column in a single digit month. If I select all of the dates and change them to MM/DD/YYYY within Planmaker and select the "Don't show zero" checkbox and then save the file. Opening it in Excel and checking the format will still show leading zero's in single digit months, also the date format will be changed to "Custom" as seen in the attached screen captures.
This may seem like an insignificant issue, but it is very frustrating and actually stops me from using Planmaker in editing any files with dates in them (which are almost all of them). I have had a similiar issue posted in the Planmaker 2008 forum for over a year and a half.
http://www.softmaker.com/forum/viewtopic.php?f=87&t=6059
Although the issue isn't exactly the same, the basic underlying problem remains. If the date format were MM/DD/YY, Planmaker would open the files without changing the dates. Unfortunately as I mentioned earlier, we can't save files in this date format.
Can someone please look into fixing this issue? If you need further information, please let me know and I will try to provide it.
Thank you
| Attachments: |
File comment: Screen captures of MM/DD/YYYY date format issues
