SoftMaker.com
English-Language Support
It is currently Mon May 20, 2013 12:02 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Batch convert tmd to pdf
PostPosted: Sat Sep 17, 2011 10:39 am
Offline
Is there a simple way to batch convert a heap of Textmaker tmd's to pdf without manually opening each and saving it?
Top
 Profile
PostPosted: Mon Sep 19, 2011 10:23 am
Offline
You can create such a script with BasicMaker. I searched the BasicMaker forum but unfortunately found no adequate script example.
_________________
Top
 Profile
PostPosted: Mon Sep 19, 2011 7:19 pm
Offline
Thank you for your trouble. I did the same and eventually found something in the samples that come with BasicMaker. It does not seem to be suitable.
I checked the commands available which include open and close for files but not for export to pdf.
I would be capable of scripting, having been a Delphi person but could not find enough information in the help.
If anybody can suggest the missing part, export to pdf, I would be grateful.
Top
 Profile
PostPosted: Tue Sep 20, 2011 8:13 am
Offline
I asked the developers.
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
cron
