SoftMaker.com
English-Language Support
It is currently Sun May 19, 2013 11:16 am
Post new topic Reply to topic  [ 10 posts ]
Author Message
PostPosted: Mon Jun 13, 2011 9:22 pm
Offline
I have always been able to print addresses in MailMerge leaving empty fields, i.e. {Address3} unprinted.
I seem to have lost this facility with the latest Update "ofw10_596.exe". Empty Address lines now print as empty lines. I have tried unsuccessfully various ways of regaining this facilility and would be grateful for any advice.
I save my address lists as ".dbf". I use Windows XP.
Juergen
Top
 Profile
PostPosted: Wed Jun 15, 2011 8:47 am
Offline
I think you are talking about TextMaker 2010, not about Presentations 2008. I moved the topic to the correct place.
_________________
Top
 Profile
PostPosted: Wed Jun 15, 2011 8:53 am
Offline
The problem has been referred to the developers. I will inform you as soon as we have an answer.
_________________
Top
 Profile
PostPosted: Tue Jul 05, 2011 6:46 am
Offline
That problem has been solved and should no longer occur wit the next service pack or next version of SoftMaker Office.
_________________
Top
 Profile
PostPosted: Fri Dec 09, 2011 9:59 pm
Offline
Sven,
I have just upgraded to SoftMaker 2012 in the full expectation that the MailMerge problem of empty address lines in TextMaker would have been solved. Not so; I still get empty lines in MailMerge addresses. I don't know what I could be doing wrong and would be grateful for your advice.
Top
 Profile
PostPosted: Sat Dec 10, 2011 3:51 pm
Offline
You are right. Contrary to what the help file says, empty lines are not suppressed in print, also in TM 2012.
Top
 Profile
PostPosted: Mon Dec 12, 2011 11:10 am
Offline
Sorry to read that. I informed the developers.
_________________
Top
 Profile
PostPosted: Mon Dec 12, 2011 2:24 pm
Offline
Thanks for this, Sven. I hope that the developers will follow it through this time. I am certain that many more users of TextMaker will be grateful for having this problem solved.
Juergen
Top
 Profile
PostPosted: Tue Dec 13, 2011 9:41 am
Offline
The problem has been solved now and won't occur anymore in the next service pack.
As a side note, this time the bug was caused by a completely different issue than last time. Let's hope that this issue doesn't ever come up again... :wink:
_________________
Top
 Profile
PostPosted: Mon Dec 26, 2011 1:24 pm
Offline
Sven,
Many, many thanks. Problem solved. Best Christmas gift ever!
Best wishes to you and all at SoftMaker für ein
FROHES NEUES JAHR!!!
Juergen 8)
Top
 Profile
Who is online
Search for:
Jump to:
