SoftMaker.com
English-Language Support
It is currently Mon May 20, 2013 4:43 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
PostPosted: Tue Jan 04, 2011 11:06 pm
Offline
Dear Sirs,
I would like to be able to open multiple instances of the program..
Is there a way to this?
Have only been able to open with Horizontal or Vertical Tile options under Windows..
Any suggestions?
Thank you
Top
 Profile
PostPosted: Wed Jan 05, 2011 8:25 am
Offline
You cannot open multiple instances of TextMaker but you can create tabs for your files.
_________________
Top
 Profile
PostPosted: Wed Jan 05, 2011 2:08 pm
Offline
rgsmiths wrote:
Dear Sirs,
Any suggestions?
Thank you
Although there are technical ways to force even SoftMaker apps to open multiple instances, this is not "data safe" for either users or the operating system. Multiple instances are a "great" way to eventually lose data, to use up a great deal of system memory, and lose a great deal of system performance.
Instead, use the multiple files tabs in SM products to do that. Works great.
Joe
_________________
Win7 Pro 64bit | Intel Multi Core i5 3.46gHz | 8GB DDR3 | 1GB Nvidia GT-9800 SP @ 1152x864 | ASUS | SoftMaker Office user / NetObjects Fusion 12 user / Serif WebPlus X5 and PagePlus X6 User / MoviePlus X6 / DrawPlus X5 / PhotoPlus X5
Top
 Profile
PostPosted: Wed Jan 05, 2011 2:31 pm
Offline
Dear Sirs,
Thank you for the reply, however
I have the resources and use 6 monitors
so having multiple instances is for me
a really important asset..
Any chance there is a way to open multiple
instances?
Any suggestions would be appreciated.
Multiple tabs is just not a good solution for me.
Thank you
Roy
Top
 Profile
PostPosted: Wed Jan 05, 2011 2:51 pm
Offline
instances?
Thats currently no possible but I referred your wish as a feature request to our developers.
_________________
Top
 Profile
PostPosted: Wed Jan 05, 2011 3:58 pm
Offline
Thank you..
2nd suggestion..
when highlighting text, would be nice
to have a 1 step process vs having to
choose Format or Right click, then
Character, then Background color
then choose the color and ok...
If one button available for "highlighting"
that could have a default color setting
it would be a lot easier to do multiple
highlights...
Thank you again.. great product!
Top
 Profile
PostPosted: Wed Jan 05, 2011 4:01 pm
Offline
rgsmiths wrote:
Thank you..
2nd suggestion..
highlights...
Drag the optional dropdown element "Background color" to one of your toolbars (Tools, Customize, Toolbars).
_________________
Top
 Profile
PostPosted: Wed Jan 05, 2011 4:27 pm
Offline
Thank you!!
That worked ..Ive got some learning to do on the configurations possible..
Top
 Profile
PostPosted: Wed Jan 05, 2011 5:59 pm
Offline
rgsmiths wrote:
Thank you..
2nd suggestion..
highlights...
RE: Invoking "highlighting text" / "giving text a background"...
OK, already answered, but for those that might like a "how-to do it"...
Jossi earlier showed us the short step-by-step way:
Try Tools >> Customise >> Toolbars.... Then, choose "Format" in the left field (Group), scroll down in the right field to "Background colour", click on the instruction icon, and draw it (drag it with the mouse) into your toolbar.
Now you can select any portion of text and highlight it in any colour you want (even different ones) from the drop-down list.
By the way, the highlighting is preserved in PDF export, too, as well as the RTF file format or when you save your Textmaker efforts as RTF. It should also be preserved when you save in other graphic-capable file formats.
The above instructions actually make it sound harder than it is, but it's quite easy to invoke highlighting and with very few steps to have to take.
Joe
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
cron
