SoftMaker.com
English-Language Support
It is currently Tue Jun 18, 2013 6:19 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: Document Path
PostPosted: Fri Oct 31, 2008 7:14 am
Offline
Not sure if what I describe in my attached file is a bug or working as designed.
The attached TMD file has the steps, description, pictures, etc. and thus hopefully make more sense than me trying to explain in this field :)
Thanks,
-Eric
DocumentPath.tmd [87.36 KiB]
Downloaded 146 times
Top
 Profile
 Post subject: Re: Document Path
PostPosted: Mon Nov 03, 2008 10:45 am
Offline
Yes, this sounds like undesired behavior. When you delete the folder, TextMaker should either go up one folder (until it finds one that exists) or revert to the default folder.
I'll report this to the developers.
_________________
Top
 Profile
PostPosted: Fri Nov 21, 2008 10:13 am
Offline
Hello,
in the next service pack our applications falls back to the SoftMaker documents folder if the last used folder no longer exists.
_________________
Top
 Profile
Who is online
Search for:
Jump to:
